Community Member
Cisco Unity Connection
Hope you all doing Great. can anyone suggest me Good Link/Book to make integration with CUCM to unity and further configuration of Unity for Call handlers and Other Voice Mail Services.
Regards-
PK
You should start by the
You should start by the online documentation:
http://www.cisco.com/c/en/us/support/unified-communications/unity-connection/tsd-products-support-series-home.html
java
if this helps, please rate
www.cisco.com/go/pdi
Community Member
Thanks Dear...
Thanks Dear...
Hall of Fame Super Red
Hi PK, In addition to the
Hi PK,
In addition to the good link(s) from Java (+5), this book from David Schulz @ Cisco is an excellent source of info;
http://www.ciscopress.com/store/cisco-unity-connection-9781587142819
Cheers!
Rob
Community Member
Thanks Rob
Thanks Rob
53
