Community Member
Cisco unity express 3.1
Hi i have 2821 router with CME 4.1 and CUE 3.1. We were having Along lines and then migrated to E1 pri. The extension where changed in CME. Now b4 the change to PRI VM was working fine. after the change i deleter all VM users in Unity and added them with the New primary extension but when users press the Msg button it says Enter USer ID followed # even when no user is given a PIN or Password. Now if You Eter the Ext No when it asks ID it says This isa not an Associated Primary Extension Number and Says Welcome to Unity Express If u have MAil box press * and when u press * the whole process repeats????? PLEASE DO HELP ME IN THIS REGARD
1 REPLY
Re: Cisco unity express 3.1
Hi Abdul,
It sounds like the calling number that CME is sending is not what CUE is expecting. Try running a debug to confirm what is actually being sent, and to see the interaction between CME and CUE.
Have you had a chance to reset CUE after the changes were made? Might be worth a shot.
Here is a sample output of 'debug ccsip messages' on a CME router while pressing the Messages button on CME phone extension 4002. The CUE pilot number is 4200. The message is a SIP INVITE, and you can clearly see what is sent to the CUE as the calling number in the 'From' field:
INVITE sip:4200@10.30.2.2:5060 SIP/2.0
Via: SIP/2.0/UDP 10.30.2.1:5060;branch=z9hG4bK314E2
Remote-Party-ID: "Ph2" <4002>;party=calling;screen=no;privacy=off
To: <4200>
Capture the output of the same debug and post here.
Hope this helps.
Michael.
93
