Community Member
Cisco Unity Express and Default L-FL-CUE-PORT-2= Amounts
OK, curiosity question:
The various SM-SRE modules, when installed with Cisco Unity Express, are supposed to have a default number of ports available.  For example, the ISM-SRE-300-K9 module is supposed to have two ports on it by default when installed with Cisco Unity Express.
When we order these modules from Cisco, they come pre-installed with CUE and the correct number of ports (default + purchased ports).  However, when we order from distribution, i.e. Tech Data, Ingram et. al., the modules come in blank whereupon we have to install CUE (no concerns here, it's easy-peasy), and then go through the hassle of contacting licensing to activate the two default ports.  Every time I call in to do this I have a different experience.
Does anyone know of a better, quicker, simpler way to activate these default ports?   No offense to licensing, but I could save a lot of time and brain cells if there was a way for me to activate them on my own.
Thanks in advance for any assistance,
Kevin
1 REPLY
VIP Super Bronze
When you order from Disti, do they give you a PAK code?  If yes, you should be able to activate it online:
https://tools.cisco.com/SWIFT/LicensingUI/Quickstart
Please remember to rate helpful responses and identify helpful or correct answers.
236
