Cisco Unity Express install
kiranoddiraju
Guys,
I have a Cisco 2811 router with c2800nm-ipvoicek9-mz.124-15.XZ1.bin image. I have setup CME on this and it works fine. Now I want to setup voice mail, please
can you let me know if this can be installed on my router? Is my router compatible to run CUE, if so what version can I install on it?
Cheers,
K
you're welcome, yes. CUE is not just a package you install on a router, it's a separate module which contains the CUE SW and the HDD for the messages
on the link you can see the requirements for each module, you'll need to see how many users will need a mailbox to determine which one to use
java
if this helps, please rate
java
6 Replies 6
Hi Kiran,
Yes, you can setup CUE on that 2811. You can get the NME-CUE or the AIM-CUE to support voicemail.
hth,
nick
Thanks and do you know how much a NME-CUE / AIM-CUE costs in UK Pounds / US Dollars?
Jaime Valencia
look here:
Cisco Unity Express Compatibility Matrix
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/compatibility/cuecomp.htm
i just looked unity express + 2811 on CCO, try using the search function of CCO
java
java
This is exactly what I was searching for...many thanks! So I need to buy a separate module now...hmmm
java
java
Great! So my option now would be to use my existing Cisco Unity instead of Unity Express. Thanks again!!!
