08-24-2010 10:23 AM - last edited on 03-25-2019 08:01 PM by ciscomoderator
hello, I'm trying to install Cisco Unity Express software on the ISM-SRE-300-K9 on a 2951 router
when i issue a service-module sim 0/0 status this is what i get
service module is cisco ism 0/0
service module supports session via tty line 195
service module is failed
service module heart-reset is enabled
service module is in fail open
service moodule status is not available
no install/uninstall in progress
could you please help me out, i need to be able to install cue on this module
thanks
Cris
08-24-2010 11:43 AM
Begin configuring the interface right, and connecting to port 2195.
08-24-2010 12:24 PM
the interface is properly configured and i can start a session properly to the cue module
and this is what i get once i start a session
SRE step 1 - SM registration...
Response - no installation needed (len: 422)
SRE Installation Not Needed
Loading disk:/bzImage ... done.
Unable to load image
Unable to boot image
Initializing memory. Please wait...
Memory initialization OK. Continue...
DDR Memory 0512 MB detected
Genuine Intel(R) processor 1.06GHz
BIOS ISM 2.6, BIOS Build date: 10/16/2009
System now booting...
any thoughts ?
08-24-2010 12:31 PM
Disk appears corrupted, from another terminal issue service-module x/y reset, try to interrupt boot process to get to boot rom, install again from scratch.
If that fails also, RMA the unit.
08-24-2010 04:28 PM
I was able to re install one CUE module without any problem now i need to figure the licensing stuff out
however on the second CUE module on the second router on the installation step 12 it fails
SRE step 12 - SM now boots Installer
Verifying ...
Corrupted netboot image detected
done.
Starting Kernel.
and then it loops
is there a way to fix this ?
08-24-2010 08:01 PM
Hello Cristobal,
Regarding licensing, if you're running a CUE version that's pre CUE 7.1, and non CSL, (shown by doing "sho software version", look for "Global" version), then you can use the traditional licenses off CCO to install/upgrade licenses, see below;
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel7_0/install/upglic.html
If you're running CUE 7.1 or later (which I believe you are, since you said you're running an ISM CUE), this is a different beast. 7.1 onwards uses CSL licenses and the licenses are enforced, below is the guide for installing/upgrading CSL licenses on CUE 7.1 and later:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel7_1/Licensing//Using_CSL.html#wp1065047
Regarding the error you're seeing, it looks as if the image is in fact corrupted. Before submitting an RMA through TAC what I'd suggest is first try to re-install the CUE software using the "boothelper" method, see below:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel7_1/install/boothelp.html
***Note, the one file that's not mentioned in the file list, in the above link, is the language package manifest file, seen below, this also nees to be downloaded, I think the link is partially wrong. The .pkg extension is for the manifest file, the link has them mixed up:
cue-vm-langpack.sme.7.1.X.pkg
The .prt1 extension file is the actual voice payload file, which loads the region specific prompts etc...(below is an examle for English US):
cue-vm-en_US-langpack.sme.7.1.X.prt1
So you'd need all the files below in total for the installation:
cue-installer.sme.7.1.x
cue-vm-k9.sme.7.1.x.pkg
cue-vm-full-k9.sme.7.1.x.prt1
cue-vm-installer-k9.sme.7.1.x.prt1
cue-vm-langpack.sme.7.1.x.pkg
cue-vm-en_US-langpack.sme.7.1.(X).prt1 (this is an example for English US language, use your own country specific lanuage payload)
Here's a link to CUE 7.1 software files:
Good luck, -Dave
08-27-2010 03:37 PM
Hello Dave,
I have a question for you,
when I'm on boot-loader for some reason I can't ping my laptop where i have the tftp server running
however if i ping my laptop from the router itself it's fine
from the ism module i can ping the int of the ism, i can't even ping the ip address of the default gateway
this is my config
interface ISM0/0
description Cisco Unity Express
ip unnumbered GigabitEthernet0/1.11
service-module fail-open
service-module ip address 172.21.17.7 255.255.255.0
service-module ip default-gateway 172.21.17.3
this is the config of the gi0/1.11
interface GigabitEthernet0/1.11
description Voice
encapsulation dot1Q 11
ip address 172.21.17.3 255.255.255.0
ip helper-address 172.21.16.21
ip helper-address 172.21.16.22
h323-gateway voip interface
h323-gateway voip bind srcaddr 172.21.17.3
end
any thoughts ?
thank you
08-27-2010 04:08 PM
never mind i got it fixed thanks all
09-09-2010 08:58 AM
Could you tell how you fix this?
I have the same problem.
09-09-2010 09:20 AM
sure.
My problem was. that I didn't have connectivity from the module to my ftp server, and then i checked the configuration on the router and i forgot to add the default route pointing to the module
something like ip route x.x.x.x y.y.y.y ism 0/0
once i put that in, I was able to install cue
09-09-2010 10:17 AM
No for this problem, but i have the problem with
System now booting
For this problem i want the result.
09-09-2010 11:30 AM
oh ok, you need to install unity express from scratch
download unity express 8.0 from cisco
then on the isr go to global config mode
and then issue
service-module ism 0/0 install url ftp://username:password@
after that you should be good to go
09-10-2010 02:17 AM
I did this without success.
Router#$url ftp://io:****@10.50.0.10/cue-vm-k9.sme.8.0.2.pkg
Delete the installed Cisco Foundation Software and proceed with new installation? [no]: y
Loading cue-vm-k9.sme.7.1.7.pkg.install.sre !
[OK - 22272/4096 bytes]
You can install upto 5 language(s) on this platform.
Please select the language(s) you want to install by entering the language number(s)
Languages can be entered as comma separated or space separated list
Example: 1,3 would select 'Italian' and 'US English'
Enter languages:
*Sep 10 06:32:40.831: %SM_INSTALL-6-INST_RBIP: ISM0/0 received msg: RBIP Registration Request3
Following languages will be installed on the system:
CUE Voicemail US English
Do you want to continue with the selected options?(y/n):y
input string: lang=no=1,CUE Voicemail US English
Router#
*Sep 10 06:32:46.607: %SM_INSTALL-6-INST_RESET: ISM0/0 is reset for software installation.
*Sep 10 06:33:06.831: %SM_INSTALL-6-INST_RBIP: ISM0/0 received msg: RBIP Registration Request
*Sep 10 06:33:06.839: %SM_INSTALL-6-INST_RBIP: ISM0/0 received msg: RBIP File Request
*Sep 10 06:33:08.711: %SM_INSTALL-6-INST_RBIP: ISM0/0 received msg: RBIP File Request
*Sep 10 06:33:33.243: %SM_INSTALL-6-INST_RBIP: ISM0/0 received msg: RBIP File Request
*Sep 10 06:33:33.711: %SM_INSTALL-6-INST_RBIP: ISM0/0 received msg: RBIP File Request
*Sep 10 06:34:04.347: %SM_INSTALL-6-INST_PROG: ISM0/0 PROGRESSING: Validating package signature ....
*Sep 10 06:34:04.599: %SM_INSTALL-6-INST_PROG: ISM0/0 PROGRESSING: Parsing package manifest files ....
*Sep 10 06:34:06.595: %SM_INSTALL-6-INST_PROG: ISM0/0 PROGRESSING: Validating package signature ....
*Sep 10 06:34:07.175: %SM_INSTALL-6-INST_PROG: ISM0/0 PROGRESSING: Parsing package manifest files ....
*Sep 10 06:34:46.563: %SM_INSTALL-6-INST_PROG: ISM0/0 PROGRESSING: Starting payload download.
*Sep 10 06:35:01.723: %SM_INSTALL-6-INST_PROG: ISM0/0 PROGRESSING: Successfully processed user input.
*Sep 10 06:35:01.755: %SM_INSTALL-6-INST_PROG: ISM0/0 PROGRESSING: Starting payload download.
*Sep 10 06:35:03.363: %SM_INSTALL-6-INST_FAIL: ISM0/0 is reset due to Error encountered while downloading payload(s) .
*Sep 10 06:35:03.363: %SM_INSTALL-6-INST_FAIL: ISM0/0 is reset due to Unable to install. Please try again.
*Sep 10 06:35:23.835: %SM_INSTALL-6-INST_RBIP: ISM0/0 received msg: RBIP Registration Request
*Sep 10 06:35:49.835: %SM_INSTALL-6-INST_RBIP: ISM0/0 received msg: RBIP Registration Request
And then stops
01-01-2011 08:25 AM
I know that this question is a few days old but I trust that other members might run into the same issue. The point of failure indicates that the language pack was not uploaded to the FTP server.
The full installation packages offer everything except for the language packs that need to be downloaded separately.
After loading the initial header files and installing the foundation software the installation continues (messages shortened for better readability:
- "Starting payload download." - This refers to the main file, i.e. 'cue-vm-full-k9.sme.8.0.2.prt1' in this case
- "Successfully processed user input." - After downloading the main file the system checks which language(s) were selected.
- "Starting payload download." - Now the selected language packs are downloaded, i.e. 'cue-vm-en_US-langpack.sme.8.0.2.prt1' in this case.
- "ISM0/0 is reset due to Error encountered while downloading payload(s) ."
- "ISM0/0 is reset due to Unable to install. Please try again."
This is the typical error message if a file is not found. At least one language pack must be installed in order to run CUE. As only one language was selected this is a critical error so that the installation fails. If you look at the log files of your FTP server you will probably notice a "505 File not found" error message as well.
05-31-2011 12:58 PM
Hey all,
I'm getting a similar problem with a CUE here, but there is a slightly difference: It's a 2821 router ( c2800nm-adventerprisek9-mz.124-25a.bin) and config for the NM-CUE module is the following:
interface Service-Engine1/0
ip address 192.168.254.1 255.255.255.252
service-module ip address 192.168.254.2 255.255.255.252
service-module ip default-gateway 192.168.254.1
ip forward-protocol nd
ip route 192.168.254.2 255.255.255.255 Service-Engine1/0
