Cisco Unity Express NME-CUE %ARP-4-NULL_SRC_MAC
I have connected NME-CUE to the router C2811. The module works all good for voicemail. Now, when Im trying to upgrade the software from version 7.1.6 to 8.6.7, using the 'Clean Install Method' it wont work. From the "BOOT-ASM" menu, after pressing ***, Im not able to reach anywhere. Not even the default gateway which is on the router. Whenever I try to reach some IP Address, out of module, it throws the following error in the ROUTER's log.
Feb  9 22:19:13: %ARP-4-NULL_SRC_MAC: NULL MAC address from 192.168.11.250 on In1/0
I have searched for this error and could not find any useful reference to this error message.
Saif
can you please post your config for that particular interface?
And would it be possible to share the URL of the document you are using as the upgrade reference?
Thanks.
G.
Here is the document used:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel8_6/install/boothelp.html
And this is the Interface config:
interface Integrated-Service-Engine1/0
ip unnumbered FastEthernet0/0.1
ip nat inside
ip virtual-reassembly in
service-module ip address 192.168.11.250 255.255.255.0
!Application: CUE Running on NME
service-module ip default-gateway 192.168.11.1
no keepalive
end
and here is the static route:
ip route 192.168.11.250 255.255.255.255 Integrated-Service-Engine1/0
the config looks alright indeed.
Any reason why you can't use the standard upgrade procedure?
G.
1196
