Cisco Unity Express Upgrade 7.0.1
Dear All,
I m trying to upgrade my unity express from 3.1 to 7.0.1...but i receive the below error message....
Downloading ftp cue-vm-k9.nm-aim.7.0.1.pkg
Download error
Can not download cue-vm-k9.nm-aim.7.0.1.pkg error code 530 error type 'Access d
enied: 530'
cue#
what can be possible task i should do to resolve this issue...
Malik.
  • IP Telephony
Re: Cisco Unity Express Upgrade 7.0.1
Can you verify that you have good connectivity to the ftp server?
Cheers,
ash
Do you have the ftp credential parameters set up correctly?
You can use this upgrade/install guide as reference:
http://tinyurl.com/mdw7ko
Dear Jleon,
I was trying to upgrade my unity using the pdf link u send. But i m facing the below problem. Can you plz help me in this regard.
cue# software download status
Download request did not complete successfully.
File retrieval error. Please verify if file is on the server.
Error transferring file : ftp download failed cue-vm-en_US-langpack.nm-aim.7.0.1
.prt1 code: 19 reason:
cue#
Malik.
360
