Cisco Unity Express : Upgrade from 2.1 to 8.0
We have a Cisco 3845 with AIM-CUE version 2.1. We are planning to upgrade the CUE to 8.0, to work with Cisco CUCM 8.5. As per compatibility matrix, the steps would need to upgrade the CUE through multiple stages to get it to 8.0. The licenses as well need to be migrated to reach the 8.0 version.
Can the AIM-CUE be upgraded to 8.0 or is a new module required?
Thanks.
You can only go as far a 7.X on AIM-CUE
Cisco Unity Express Compatibility Matrix
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/unity_exp/compatibility/cuecomp.htm
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
CUE 7.3 is compatible with CUCM 8.5, so this solves the requirement. Also, believe the licenses can be migrated accordingly.
thank you for the response.
Hall of Fame Super Gold
I'm not sure why someone has low rated the post above by Java, that is 100% correct, and made to help.
To partially balance the mistake, I have rated for what is worth: 5 stars.
Please think before clicking.
HI,
I have same problem , I want upgrade from 2.1 to 7.4 , I have only 7.4 required file , I don't know if you luck to upgrade direct from 2.1 to 7.X or not , or should I upgrade in 3 step 2.1 --> 2.2 --> 3 --> 7.0 ?
Please if you succed to upgrade , post the step .
Best Regards
Marwan
Marwan,
I am almost sure that you will have to follow that longer path only. You can confirm the same by referring to CUE 7.0 release notes guide & then you will find the lowest possible version from which the upgrade is allowed. In this case mostly it will be 3.x. Then again refer CUE 3.x's release notes guide & you will realize that 2.x is the lowest possible version from which an upgrade to 3.x is possible. Thus you will drill down to your present version & chalk down the upgrade path, which is mostly 2.1 --> 2.2 --> 3 --> 7.0.
Hope it helps ?
GP.
Pls rate helpful posts by clicking on stars below the post !!
664
