Cisco Unity Express Voice-Mail AIM
Hi all.
Scenario
When I receive a voice mail on unity I would like a script (externally written for me) to send a message to my mobile telling me I have a voice mail on the system, I know that if I look under my mail box there is a field that tell me how many old messages and how many new messages I have, I'm trying to find this field using cli, could somebody let me know where I find the number of new mails waiting using cli.
Martyn
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Cisco Unity Express Voice-Mail AIM
Hi, you do not need to do an incremental upgrade.
You can download the files for a fresh installation, including bootloader, for the release you want.
The license files can be downloaded too.
In any case you will likely have made a backup of configuration and custom prompts, etc.
Please remember to rate useful posts with the scrollbox below.
If you configure VM notification, and subscribe an email-to-SMS service, you should have this quite easily.
Thank for your reply, I appreciate it.
Because I'm monitoring my systems I would prefer it if my mobile rang, that way I do not sleep through a text alert.
Martyn
Above you asked for SMS and I've replied to that. If you want to be called, just configure notification to Phone Device.
Sorry I did say message when it should of been call, which like you say did answer.
Thanks for you reply and I will take a look into this.
Martyn
Can you post a link to the solution please, I can not find anything on Cisco that is helping me.
Cisco Unity Express Version 2.1
Cisco Unity Express AIM-CUE
Martyn
Guess this can not be done with AIM-CUE, is this correct?
Yes it can be done, but you need to update you SW, 2.1 is really too old.
Thanks again for the reply, so if I want to get to 3.1 I need to follow this upgrade path.
cue-vm-upgrade 2.1.3 2.2.2 prt1
Then
Cue-vm-en_GB-lang-pack.2.3.4.prt1
Then
Cue-vm_GB-upg-langpack.nm.234_3.0.1.prt1
I did look on the site but could not find my answer, also as its an upgrade I do not need to chance my license do I?
Thanks again
214
