12-13-2007 01:14 AM - edited 03-15-2019 07:45 AM
I have a problem with Cisco Unity Express. When the user calls his mailbox he is asked for his Extension ID followed by #.
After typing it in he gets the message: "For security reasons initial access to the mailbox is only available from the primary extension."
How can I make the mailbox accessible from all the phones?
Moe
12-13-2007 01:42 AM
I guess the user should first access his Mailbox from his own extension and "then" by doing the first logging, he will be able to access it from everywhere.
12-13-2007 01:51 AM
Hi Zin,
I thought so too, but the problem is, that we are trying it from the useres own extension. There must be a configuration point where you can turn this security aspect off, but I cant find it.
12-13-2007 06:12 AM
Hi Moe,
Just a guess here, but was a Primary Extension defined for this user?
Clip ***In the Primary column, use the drop-down menu to select a primary extension for that subscriber.
The primary extension is the mailbox for receiving, saving, and retrieving voice-mail messages. If no primary extension is designated for a subscriber, that subscriber cannot receive, save, or retrieve voice-mail messages.
In this field, None means that none of the displayed extensions for the subscriber is the primary extension. You can designate a mailbox for this subscriber now, but the subscriber cannot access it until you configure the subscriber's primary extension at a later time.
From this doc;
Hope this helps!
Rob
12-14-2007 05:13 AM
Hey rob,
I now found a workaround. There was a problem with the passwords and pins of the users. After changing them the mailbox was accessible again. Seems to be a bug or something like that. Maybe there was no Pin configurated for some of the useres before.
But thank you for your help.
Cheers
Moe
