Community Member
Cisco Unity: Greetings Administrator
How could I change the Greetings Administrator user id and password on Cisco Unity.
My network administrator has changed and new admin wants to use his own id and password.
1 REPLY
Re: Cisco Unity: Greetings Administrator
To access the Cisco Unity Greetings Administrator, the owner of the call handler will require the following information:
The phone number to dial for access to the Cisco Unity Greetings Administrator
The ID of the call handler owner
The password of the call handler owner
The extension of the call handler
To prevent unauthorized access to Cisco Unity, make sure that the call handler owner understands that the above information should be kept confidential.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/administration/guide/ex/5xcusag250e.html
Change the owner of the call handler
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
1399
