Community Member
Cisco Unity : impossible to contact the server
Hy, I have install cisco unity, to function with the CallManager service. but when I go on the page https://address_of_my_unity_server/ciscopca/ i have an error message "impossible to contact the server".
Is someone can help me ?
ps: sorry I'm french
Silver
Re: Cisco Unity : impossible to contact the server
1- can you browse that page on the Unity server itself?
2- can you ping unity IP address from the computer you are trying to access unity from.
3- did you use http:// ip adress instead of https.
4-which unity version are you using? which internet explorer version?
aller explique nous et on vas t aider ;)
Karzazi
Community Member
=> yes, it's the same
=> yes it works
=> yes but automatically it put https://
Unity v4.2 and IE 6
Community Member
=> yes it works
Unity v4.2 and IE 6
Silver
260
