Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Cisco Unity latest version
Hi all,
Could you tell me what is the latest version of CISCO Unity ? Also, how many component and devices I want to buy for about 70 voice mail?
Leung Che Man
1 REPLY
Re: Cisco Unity latest version
The latest version of Cisco Unity that I would recommend to a customer is 7.0.  The most current version you can buy is 8.0.  70 users is a really small deployment so what you buy would really depend on your requirements.  Unity can be deployed as UM or voicemail only.  For UM, you could buy a 7825 server with and licensing for your users and have plenty of capacity left assuming you have no redundancy requirement.  If you are going to go voicemail only, I would recommend Unity Connection instead.  Recommended version right now would be 7.1(3b)SU2; however, 8.0 is available.  As an alternative, if you do not already have CUCM - then you could opt for the CUCM Business Edition which is more than adequate for your user base (size wise) and includes both CUCM and Unity Connection co-installed on a custom 7828 server platform.
Hailey
Please rate helpful posts!
383
