Cisco Unity message store wizard failed
I am installing Cisco Unity in a lab environment. I have install Echange 2003 on a host and i am installing Cisco Unity on another host. exchange services appear to be running properly, but when i start the Message store wizard it fails generating the two following events
Event ID 137: CiscoUnity_UMR
"Attempts to deliver Unity message Repository message have failed due to Unity configuration or connectivity to with the partner mailserver"
Event ID 32029 CiscoUnity_Doh
" Cisco Unity was unable to access the msg store due to config error"
It seems i have a connectivity issue, i however feels the exchange service is up and the hosts can communique between each other. I don't have any firewall. I running all those hosts on an Esx server.
The Unity server is running
Any hints on how i should troubleshoot this issue?
1 REPLY
Re: Cisco Unity message store wizard failed
i would say to re-run the PW, make sure you have delegated control and re-run the MSCW
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
147
