Cisco Unity Ports issue
kraghavansag
Recently I added additional ports in the unity telephony integration manager for the integration with CCM. The ports are registered with CCM and everything works great. The issue is that, i am not able to see the DNs of new the ports added in UTIM where as the old ones are listed correctly. Am I missing anything here?
mightyking
Level 6
Level 6
Are the new ports licensed?
MK
Yes. I would not able to add new ports if there are no additional licenses.
did you restarted unity after modifying the integration in UTIM??
java
if this helps, please rate
java
Yes. I did multiple times. It looks like I may have to re-add the ports again in Unity. A TAC engineer suggested that.
