Cisco Unity system call handler issue
I'm having an issue with recording a voice greeting with a system call handler i'm setting up.  I'm trying to use the phone where Cisco Unity calls my phone so I can do the recording over the phone instead of using my computer.
I'm getting an error message.  See attachement.  Any idea how this can be fixed?
Cisco Unity Connection version: 7.1.3.10000-68
Re: Cisco Unity system call handler issue
check your CSS and make sure the ports can dial your DN
I checked the CSS on each voicemail port and it was set correctly.
Look at the Unity restriction tables and make sure you can dial the DN.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
ah, well I looked in here I noticed something very weird.  Minimum length of dial string* was set to 9.  Our internal DN's are set to 5.  I set that field to 5 and tried it again and it worked.  Thank You
214
