CISCO VG 248 NO TONE ON PHONES IN CERTAIN MOMENTS
I´m having issues with a cisco vg248. Certain phones does not have tone for a few moments and then get back the tone. After review the vg I found low voltage warning and high cpu utilization. The high cpu utilization is happening like every 5 minutes. Then I look further and I found that the low voltage warning is a bug with the hardware (CSCse83429). It´s posible that the problems mentioned are affecting the phones on the vg? Do you think that doing a RMA will fix the issue?.
Thanks a lot for the help that you can give me.
Edgar
204
