cisco VG to PBX problem
I have coonectd my router via a wvic (E1 Qsig) to a pbx.
the pbx users can call my fxs ports and they can talk,but the problem is when I try to call them from FXS analoge telefone tp PBX users.. their phone will ring but I can not hear anythig and also when they pick up the phone no timeslot will be activated and therefore i can not here their voice.
please help me
Re: cisco VG to PBX problem
Could you post the following-
1. sh run
2. deb isdn q931 / deb voice ccapi in out
Subhrojyoti
BX-VG#
*Oct 16 11:00:49.147: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x16 is 0x0 0x0, Calling num 8
*Oct 16 11:00:49.147: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x16 is 0x0 0x0, Called num 2830
*Oct 16 11:00:49.151: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x008E
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9838A
Exclusive, Channel 10
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0080, '8'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '2830'
*Oct 16 11:00:49.243: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x808E
*Oct 16 11:00:49.247: ISDN Se0/0/0:15 Q931: TX -> STATUS pd = 8 callref = 0x008E
Cause i = 0x80E018 - Mandatory information element missing
Call State i = 0x01
*Oct 16 11:00:49.271: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x808E
*Oct 16 11:00:49.275: ISDN Se0/0/0:15 Q931: TX -> STATUS pd = 8 callref = 0x008E
Call State i = 0x01
*Oct 16 11:00:49.283: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x808E
*Oct 16 11:00:49.287: ISDN Se0/0/0:15 Q931: TX -> STATUS pd = 8 callref = 0x008E
Call State i = 0x01
*Oct 16 11:01:05.367: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x008E
Cause i = 0x8090 - Normal call clearing
*Oct 16 11:01:05.439: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x80
Can you try this?
voice call send-alert > under global config
progress_ind alert enable 8 > under the voice dial-peer # pots configuration
Subhrojyoti
hi
i have provided them before but nothing happend
the problem remains! :(
174
