07-24-2013 05:52 PM - edited 03-16-2019 06:32 PM
One of my cisco VG224 is experienced busy tone when people calls while its registered fine in CUCM 6.3. Outgoing calls from that port is working fine. It works as SCCP with CCM.
Any help will be appreciated
Sent from Cisco Technical Support Android App
07-24-2013 06:20 PM
Can you receive outside calls, to other devices? Did you change any CSSs or TPs?
07-25-2013 12:47 AM
Can you share your VG config file? Please paste the out put of the command "sh stc dv summ"
Thankyou
PC
07-25-2013 01:06 AM
Have you checked that there's no divert set ?
GTG
07-25-2013 02:22 PM
I can receive calls to other phones connected to same VG. Issued port has partition (none), CSS (none). And there is no call divert. Outgoing calls works fine the problem with income call. I will paste config when I will got it next Sunday.
07-25-2013 11:59 PM
In the non-working phone, apply the same partition you see it in working phone. Please share the config as well.
Thankyou
PC
