Cisco voice gateway with FXO card
Dears,
I have CUCM connected with Voice Gateway router.
I put a VIC-4FXO card to provide access to the PSTN and receive calls from the PSTN.
Now my problems are:-
1- When I receive a call from the PSTN the cisco phone still ringing (hangup) in spite of that the PSTN close the call.
2- When I try to call from cisco phone to the PSTN there is delay approximateley 10 - 12 seconds.
Apprecite your support,
Green
Ali,
You are facing a couple of issues
1) the fxo disconnect issue
http://www.cisco.com/c/en/us/support/docs/voice/analog-signaling-e-m-did-fxs-fxo/8120-fxo-disconnect.html
2) You seem to have a inter digit tme out misconfig with your dial peers etc.
May be you could explain your set up in more detail
Are you using H323, MGCP or SIP to talk between your CUCM and v/gway
Could you post your v/gway config
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
My VG configured as MGCP you can find below the configuration:-
voice-card 0
dspfarm
dsp services dspfarm
license udi pid CISCO2901/K9 sn FCZ1801C252
hw-module pvdm 0/0
username ibs privilege 15 password 0 ibs
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1
description Connected to LAN
ip address 10.10.4.8 255.255.255.0
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 10.10.4.1
control-plane
voice-port 0/0/0
timing hookflash-out 50
timing guard-out 1000
caller-id enable
voice-port 0/0/1
caller-id enable
voice-port 0/0/2
caller-id enable
voice-port 0/0/3
caller-id enable
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.10.4.7
ccm-manager config
mgcp
mgcp call-agent 10.10.4.7 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/1
mgcp bind media source-interface GigabitEthernet0/1
mgcp profile default
sccp local GigabitEthernet0/1
sccp ccm 10.10.4.7 identifier 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register HW-CFB_HQ-1
dspfarm profile 1 conference
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 2
associate application SCCP
dial-peer voice 1 pots
service mgcpapp
port 0/0/0
dial-peer voice 999000 pots
service mgcpapp
port 0/0/0
dial-peer voice 999001 pots
service mgcpapp
port 0/0/1
dial-peer voice 999002 pots
service mgcpapp
port 0/0/2
dial-peer voice 999003 pots
service mgcpapp
port 0/0/3
Now to solve my first issue shall I configure the below on my voice ports??
(config)#voice-port x/x/x
FXO_Paper(config-voice)#supervisory disconnect signal
FXO_Paper(config-voice)#end
FXO_Paper#
So the phone stop ringing at one the other part close the call
Silver
You have to find specific disconnect tones for this to work on FXO...maybe you can try with this one (this is for Serbia BTW):
voice class dualtone-detect-params 1
freq-max-deviation 25
cadence-variation 25
voice class custom-cptone disconnecting
dualtone disconnect
  frequency 425
  cadence 500 500
voice-port 0/0/0
supervisory disconnect dualtone mid-call
supervisory custom-cptone disconnecting
HTH,
Dragan
HTH, Dragan
Dragan,
I tried the above but still facing the same issue,
Please advise
Hi Alex,
I posted my VGW config please advise,
Re:Cisco voice gateway with FXO card
This may be a common disconnect issue. Need to create a Custom cp-tone. Is this site based in the middle east?
A PCM capture would help:
https://supportforums.cisco.com/docs/DOC-14060
Kevin
Sent from Cisco Technical Support Android App
Yes in Middle east
I can't find any specific configuration for this issue??
Re: Cisco voice gateway with FXO card
Hi Ali
1- This is a famous problem , i hope to take a look for the below
A-  to get your frequency and cadence , use the below:-
http://www.3amsystems.com/World_Tone_Database
B-Try to use the below
http://ciscoflair.blogspot.com/2009/05/cisco-fxo-disconnect-issue.html
C-If you go to H323 , This will be the best choice.
Please rate all useful information
PCM capture and send it to Cisco to get you the frequency and cadence
They have internal tool which can analyze the disconnect signal properly
As Islam gave a external tool to decode the PCM capture.
Converting it to h.323 will solve half but not entirely of your problems.
Try capturing the PCM. Send it across.
Kevin
I sent you the PCM file,
440
