Cisco Voice OS file search command
I am trying to find a log file on my Unity Connection 9.1 server but am not having any luck.
diag_CuCsMgr_*.uc - this is the file I need to locate (the * is a wildcard and will be replaced with something else)
Does anyone know the path to this file? (I cannot use RTMT due to customer security policies)
I have tried using the file search command but cannot work out how to use it. The help for the command is shown below:
admin:file search activelog ?
Syntax:
file search activelog file-spec reg-exp [options]
file-spec   mandatory   file to view
reg-exp     mandatory   regular expression which is to be searched. To include "s escape them with \.
options     optional    reltime days|hours|minutes timevalue
                        abstime hh:mm:ss mm/dd/yyyy hh:mm:ss mm/dd/yyyy
                        ignorecase,recurs
Can anyone give an example of a file search query? I am not sure what to put for file-spec and reg-exp
Everyone's tags (2)
If your looking for a basic file search query...
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cli_ref/7_1_2/cli_ref_712.html#wp39720
file search activelog platform/log/platform.log Err[a-z] ignorecase
But if you want to search for the path of a file use file list coomand
Let me know if this is helpful.
Thanks Gregory,
I was getting confused about what the file search command was for.
It would be useful if there was a Cisco equivalent of the Linux find command!
Re:Cisco Voice OS file search command
Hey James
Not sure if that can help, anyway follows my contribution to try help you... On this site (http://ucguerrilla.com) Bill (community contributor )explain some SQL query probably it can be helpful
Cheers
Bruno Rangel
Sent from Cisco Technical Support Android App
Cheers Bruno Rangel Please remember to rate helpful responses using the stars bellow and identify helpful or correct answers .
471
