cisco voicemail account locked
Hi all,
We have Cisco Unity Connection  Administration 7.0 and problem is for one user
we reset the voice mail password for the user and it gives us error : user account
has been locked out please contact system adminstrator.
We tried the following things
1) we checked the user  profile account is not locked out.
2) we reset the password but it want' work still give same error message
3) we recreated the whole mail box but still same issue
4) tried to access the user from the outside but still gives same error message.
5) user does not have any other number association.
Waiting for your help. Thanks in advance
Hi Samir,
Confirm the user don't have the locked account  check box marked
If so , delete it , re-import it again from cucm
Haitham
Hi Haitham,
I checked that and user don't have lockec account check box marked.
we delete the user account and recreated but still same issue.
samir
Hello Samir
Can you also check the below?
Also, verify these settings under the Edit Authentication Rule on Cisco Unity Connection Administration:
  • The number of failed logon attempts that are allowed before an account is locked.
  • The number of minutes an account remains locked before it is reset.
  • The number of days before a password expires.
Thank you
Please rate all useful information
Hi kamal,
Here is the answer :
•The number of failed logon attempts that are allowed before an account is locked. : 5
•The number of minutes an account remains locked before it is reset. : 15
•The number of days before a password expires. : never expires
samir
Bronze
Hi Samir,
Have you used the port status monitor to make sure that the call is going where you think it's going to?
If the call flow looks good, can you try recreating the user with a different user template?
Gareth
Hi Gareth,
we tried that things but it does not work. and also we delete the voice mail box for that particular
number and when user press the message button it stil goes for voice mail.
samir
1-I am so sorry for you that your problem still running. Please can you change the number of the below which you shared before , make it any big number (50 for example or 0).
2-Try to change the userid and readd the account again.
Thank you
please rate all useful information
4937
