Cisco Voip Router to Linksys Voip Router Call
I have Cisco 1760 voip router with two fxs ports. And have Linksys WAG54GP2-E2 voip router. I make peer-to-peer call. Linksys router can call to cisco but cisco can not call linksys. Does anybody know how i resolve this problem. Thank for help.
Ufuk Guler
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Cisco Voip Router to Linksys Voip Router Call
You are right, I had totally oversight that you was missing that command under DP!
Good that you've found about it eventually.
How DP on the 1760 is configured, and what do you see from "term mon" and "debug ccsip message" ?
Here is DP,
dial-peer voice 200 voip
description *****CISCO TO LINKSYS*****
destination-pattern 200
voice-class codec 1
session target ipv4:81.x.x.x
dtmf-relay cisco-rtp
no vad
When i test with csim start 200 command i take this messages
csim: called number = 200, loop count = 1 ping count = 0
csim err csimDisconnected recvd DISC cid(507)
csim info: cid(507), state(0), cause(38)
csim: loop = 1, failed = 1
csim: call attempted = 1, setup failed = 1, tone failed = 0
cause 38 is network out of order. Please collect the above mentioned debug to find why.
I have checked some debug messages which are debug cch323 all. I saw that peer to peer calls like H.323 calls. And linksys accepts only SIP calls. Because of that Cisco's calls unrecognized with Linksys. Then I wrote "session protocol sipv2" command in the dial-peer. And finally, cisco calls started successfull1y to linksys.
I would like to thank you for your help.
Have a nice days...
456
