03-30-2010 04:38 PM - edited 03-15-2019 10:02 PM
Hi all,
I am working on upgrading my CUCM infrastructure from 4.1.3 to 7.1.3. I have quite a few users using Cisco VTA 2.1.1 and IP Communicator 2.1.3. I would like to find out if Cisco VTA 2.1.1 and IP Communicator 2.1.3 will work with CUCM 7.1.3 or do I have to upgrade Cisco VTA and IP Communicator at the same time I am upgrading CUCM ? My plan is to upgrade CUCM first then slowly upgrade Cisco VTA and IP Communicator and would like to make sure the existing version of VTA and IP Communicator is compatible with CUCM 7.1.3.
Thanks in advance !!!!
Danny
Solved! Go to Solution.
03-30-2010 04:44 PM
Everything you need should be here http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html.
Hailey
Please rate helpful posts!
03-31-2010 12:37 AM
That's correct - I use CIPC a lot in my lab and switch between versions of CCM very regularly (from 4 thru 8). I never upgrade or downgrade CIPC unless I'm rebuilding a PC, and it always works so far...
Aaron
Please rate helpful posts...
03-30-2010 04:44 PM
Hailey
03-30-2010 05:10 PM
Thanks David !! I appreciate your response !!!
I've looked at the link you sent and seems like the latest supported CUCM version for VTA 2.1.1 and IP Communicator 2.1.3 is CUCM 6.1.
If I understand correctly VTA 2.1.1 and IP Communicator would still work with CUCM 7.1.3 you just don't get the full feature of CUCM 7.1.3. Do you know if that is true ?
Thanks again !!!
Danny
03-31-2010 12:37 AM
Aaron
03-31-2010 08:42 AM
Hi Aaron !! I appreciate your response !!! Did you have a chance to test CUCM 7.1.3 with Ciso VTA 2.1.1 ?
Thanks !!
Danny
03-31-2010 09:51 AM
Nearest I have is CIPC 2.1.3, running on Windows 2000. This works fine with CUCM7.0 and the 8.0 beta... so should be OK in between.
Aaron
