Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Cisco VWIC-1MFT-T1 Voice-Port Problem
Hi guys,
I'm trying to configure a T1 controller (VWIC-1MFT-T1) for voice which is installed on a 2651XM (12.4(15)T9).
After I've set it up, it came up and the serial0/0:0 was created and was up.
The problem is I can't find any voice-port in the config. It seems the voice-port 0/0:0 isn't created.
Has anyone had this issue before?
#sh run | i voice-port
Thanks.
Stephan,
Would you please provide output for the following commands? Thanks.
sh run
sh isdn service
sh isdn status
VIP Purple
Can u also share the show diag/ show inventory  as well ?
Have u inserted VWIC in NM-V card?
regds,
aman
Hi,that's the problem I think
that's the problem I think. It must be used with a nm-v card.
I found this post https://supportforums.cisco.com/discussion/11758746/using-vwic-1mft-t1-voice-pri-2610xm
same problem.
Re: Cisco VWIC-1MFT-T1 Voice-Port Problem
Hi Stephan,
Do you see the controller T1 when you do the show running. If not then you have to run commands card type t1 slot#.
Slot # can be easily got from sh inventory result.
after that it would be activated and then you woule be able to see and configure T1, also would be able to configure the serial interface.
Kind Regards,
Raaj.
104
