Cisco x IPC - Q921: Net TX -> SABMEp
Guys,
Can someone help?
I'm trying to connect to IPC alliance over a E1 Link. The configuration is below.
I'm receiveing this message when debuging ISDN Q921:
*Jul  5 17:38:59.735: ISDN Se0/1/1:15 Q921: L2_EstablishDataLink: sending SABME
*Jul  5 17:38:59.735: ISDN Se0/1/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
My ISDN status is:
BTG-COL-VG#show isdn status
Global ISDN Switchtype = primary-qsig
ISDN Serial0/1/0:15 interface
        ******* Network side configuration *******
        dsl 0, interface ISDN Switchtype = primary-qsig
         **** Master side configuration ****
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0xFFFF7FFF
    Number of L2 Discards = 0, L2 Session ID = 98
ISDN Serial0/1/1:15 interface
        dsl 1, interface ISDN Switchtype = primary-qsig
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
    Layer 3 Status:
    Active dsl 1 CCBs = 0
    Total Allocated ISDN CCBs = 0
Part of the show run:
BTG-COL-VG#show run
Building configuration...
Current configuration : 3515 bytes
version 12.4
service password-encryption
hostname BTG-COL-VG
boot-start-marker
boot-end-marker
logging buffered 100000
enable secret 5 $1$86J6$M9vu8saSudfsVIycg25tZ0
no aaa new-model
network-clock-participate wic 1
ip cef
no ip domain lookup
isdn switch-type primary-qsig
voice-card 0
voice service voip
address-hiding
allow-connections sip to sip
redirect ip2ip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
sip
  bind control source-interface FastEthernet0/1
  bind media source-interface FastEthernet0/1
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g722-48
codec preference 4 g722-56
codec preference 5 g722-64
codec preference 6 g723ar53
codec preference 7 g723ar63
codec preference 8 g723r53
codec preference 9 g723r63
codec preference 10 g726r16
codec preference 11 g726r24
codec preference 12 g726r32
codec preference 13 g728
codec preference 14 g729br8
codec preference 15 g729r8
codec preference 16 gsmamr-nb
codec preference 17 gsmefr
codec preference 18 gsmfr
codec preference 19 ilbc
codec preference 20 clear-channel
voice translation-rule 1
rule 1 /^756/ //
voice translation-profile incoming_pstn
translate called 1
controller E1 0/1/0
clock source internal
pri-group timeslots 1-31
controller E1 0/1/1
interface FastEthernet0/0
description LAN
ip address 10.26.33.20 255.255.255.0
speed 100
full-duplex
ip address 192.168.150.2 255.255.255.248
duplex auto
speed auto
interface Serial0/1/0:15
no ip address
encapsulation hdlc
no logging event link-status
isdn timer T310 300000
isdn protocol-emulate network
isdn incoming-voice voice
isdn supp-service name calling
no cdp enable
interface Serial0/1/1:15
no ip address
encapsulation hdlc
no cdp enable
ip route 0.0.0.0 0.0.0.0 10.26.33.1
ip route 10.7.17.226 255.255.255.255 192.168.150.1
ip http server
no ip http secure-server
disable-eadi
control-plane
voice-port 0/1/0:15
cptone CO
voice-port 0/1/1:15
cptone CO
  • IP Telephony
231
