cisco2800 /netmeeting voip & PSTN
hi
I want to configure my cisco 2811 (IOS ...) in order to place calls between 2 PC with netmeeting (voip) and between 1 PC with netmeeting (voip) and external PSTN thru (FXO) .
Nothing is working at all .
Is there any command to troubleshoot what is happening during these 12 kind of calls ?
and here please find attached the show tech of my cisco 2800 router
regards
thank a lot
Re: cisco2800 /netmeeting voip & PSTN
hello and thanks friend
I used your URL and I made some progress because I can now make call from netmeeting to PSTN however I still can't make any incoming call from Outside PSTN to my PC netmeeting thru my Cisco 2811!!!
so please have a look to my debug display and my SHOW RUN config below in order to help me asap
best regards
Current configuration : 1228 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
enable secret xxx
enable password cisco
no aaa new-model
resource policy
network-clock-participate wic 1
ip cef
voice-card 0
no dspfarm
voice service voip
h323
interface FastEthernet0/0
ip address 10.10.10.10 255.0.0.0
duplex half
speed auto
no mop enabled
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
clock rate 2000000
--More--
interface BRI0/1/0
no ip address
interface BRI0/1/1
no ip address
ip http server
no ip http secure-server
control-plane
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/3/0
voice-port 0/3/1
dial-peer voice 1 pots
destination-pattern .
direct-inward-dial
port 0/2/0
dial-peer voice 2 voip
session target ipv4:10.0.0.3
dtmf-relay h245-signal
codec g711ulaw
debug voip dialpeer all
Log Buffer (4096 bytes):
167: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerSPI:exit@5927
*May 23 19:51:19.887: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=, Called Number=, Voice-Interface=0x46BF2CD0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_PORT;
Result=Success(0) after DP_MATCH_PORT; Incoming Dial-peer=1
*May 23 19:51:19.887: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerSPI:exit@5927
*May 23 19:51:23.967: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*May 23 19:51:23.967: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerSPI:exit@5927
145
