05-06-2008 07:29 AM - edited 03-15-2019 10:28 AM
Hi, I've specced this up for a customer. I've also added a VWIC2-1MFT-T1/E1= . I dont need to order any DSP's do I? ie they should come as part of the bundle surley?
Solved! Go to Solution.
05-06-2008 07:42 AM
I believe this bundle comes with a PVDM2-8 - an 8 channel DSP module.
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/product_data_sheet0900aecd804e773d.html
To support 24 channels on the VWIC2-1MFT-T1/E1, you would need a minimum of 2 DSPs - a PVDM2-16 + one PVDM2-8. Check the DSP calculator for confirmation:
http://www.cisco.com/cgi-bin/Support/DSP/dsp-calc.pl
Hope this helps.
Brandon
05-06-2008 07:42 AM
Hope this helps.
Brandon
05-06-2008 07:56 AM
spot on, thanks mate
