CISCO2921/K9 w/ PVDM3-64
Hi -
New SRST gateway I'm installing has PVDM3-64 installed. When booting the router I get the following warning:
Warning! DSPs1, 2,  in slot 0 are using non-default firmware from flash:
This is not recommended, the default version is 26.3.6
But when I do a show voice dsp detailed the installed DSP shows the correct firmware it says I should be using.
EOGrvMUSshawn01#show voice dsp detailed
DSP  DSP                DSPWARE CURR  BOOT                         PAK     TX/RX
TYPE NUM CH CODEC       VERSION STATE STATE   RST AI VOICEPORT TS ABORT  PACK COUNT
----------------------------FLEX VOICE CARD 0 -----------------------------
                           *DSP VOICE CHANNELS*
CURR STATE : (busy)inuse (b-out)busy out (bpend)busyout pending
LEGEND     : (bad)bad    (shut)shutdown  (dpend)download pending
TYPE   NUM CH CODEC        VERSION STATE STATE   RST AI VOICEPORT TS ABRT PACK COUNT
SP2600 001 01 None          26.3.6 idle  idle      0  0                 0          0/0
SP2600 001 02 None         26.3.6 idle  idle      0  0                 0          0/0
SP2600 001 03 None          26.3.6 idle  idle      0  0                 0          0/0
SP2600 001 04 None          26.3.6 idle  idle      0  0                 0          0/0
SP2600 001 05 None         26.3.6 idle  idle      0  0                 0          0/0
SP2600 001 06 None          26.3.6 idle  idle      0  0                 0          0/0
EOGrvMUSshawn01#show inv | inc PVDM3
NAME: "PVDM3 DSP DIMM with 64 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 64 Channels"
PID: PVDM3-64          , VID: V01 , SN: FOC16311779
Any suggestions to why this warning message is showing and if it will cause problems is much appreciated!
Tom Fredericks
Hall of Fame Super Silver
Re: CISCO2921/K9 w/ PVDM3-64
Do you have other firmware files defined on flash?
Can you post "sh flash"?
Not that I can see. Just have the default files that come with the router and the IOS bin.
EOGrvMUSshawn01#show flash
-#- --length-- -----date/time------ path
1         2903 Aug 14 2012 02:09:04 cpconfig-29xx.cfg
2      3000320 Aug 14 2012 02:09:16 cpexpress.tar
3         1038 Aug 14 2012 02:09:24 home.shtml
4       122880 Aug 14 2012 02:09:32 home.tar
5      1697952 Aug 14 2012 02:09:46 securedesktop-ios-3.1.1.45-k9.pkg
6       415956 Aug 14 2012 02:09:58 sslclient-win-1.1.4.176.pkg
7         2962 Aug 22 2012 15:01:38 -0
8     62759344 Aug 22 2012 15:17:08 c2900-universalk9-mz.SPA.150-1.M2.bin
9        14042 Aug 22 2012 15:22:36 -1
10       11901 Aug 24 2012 14:14:50 -2
11       14021 Aug 24 2012 14:35:16 -3
12       14021 Aug 24 2012 14:43:04 -4
188407808 bytes available (68079616 bytes used)
Hall of Fame Super Gold
Update IOS and check again.
Hi Paolo -
I have tried with two different IOS versions and gotten the same result.
c2900-universalk9-mz.SPA.150-1.M8.bin
Then if you no operational problem, you can ignore the message.
635
