I have a Cius. When I power it on, it does not go past the Cisco logo. It just keeps showing and refreshing the Cisco Logo with the bridge. My boss does not want to erase the configuration, just reset it so it boots if possible.
Mine did that once and I had no option but to do the factory reset so that I could use it again.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
