Clarifications of CUBE
Hi All - I do have few clarification on below points.
1. Media Flow Around and Media Flow through have any link with Codec Negotiation and Transparent.
Lets say i have configured Media flow through and codec transparent will it work in such cases because Media Transparent allow two end points to negotiate codec and Media Flow around will change the codec according to O/B call leg which point to SIP Trunk (ITSP)
SIVANESAN R
  • IP Telephony
1 REPLY
Codec Negotiation is the part
Codec Negotiation is the part of the signalling process , it will not affect media flow. Media flow depend upon the SDP media IP and port.
What Media flow through does it changes outbound call leg media IP/port to CUBE's ip/port so that media will flow through CUBE and its used for address hiding and security.
Media flow around will let the RTP stream to flow directly between end points.
Manish
85
