class-map question match-any vs match-all
Are the following class-maps equivalent since there is only one match statement in them?  or does the any/all apply to "af41 and/or cs4"
class-map type qos match-any VIDEO
     match dscp af41 cs4
class-map type qos match-all VIDEO
     match dscp af41 cs4
Brian Holmes
Verizon Enterprise for Chrysler
Brian Holmes Verizon Enterprise for Chrysler
Everyone's tags (3)
No, in the match any if can only match either of the 2 and it wil be put in that traffic class, on the any statement i needs to match both values. That is what I understand from the explanation below.
Creating a Traffic Class
To create a traffic class, use the class-map command. The syntax of the class-map command is as follows:
class-map [match-any | match-all] class-name
no class-map [match-any | match-all] class-name
The match-all and match-any Keywords
The match-all and match-any keywords need to be specified only if more than one match criterion is configured in the traffic class.
The match-all keyword is used when all of the match criteria in the traffic class must be met in order for a packet to be placed in the specified traffic class.
The match-any keyword is used when only one of the match criterion in the traffic class must be met in order for a packet to be placed in the specified traffic class.
If neither the match-all nor match-any keyword is specified, the traffic class will behave in a manner consistent with match-all keyword.
About The match not Command
The match not command, rather than identifying the  specific match parameter to use as a match criterion, is used to specify  a match criterion that prevents a packet from being classified as a  member of the class. For instance, if the match not qos-group 6 command  is issued while you configure the traffic class, QoS group 6 becomes  the only QoS group value that is not considered a successful match  criterion. All other QoS group values would be successful match  criteria.
Voice CCIE #37771
But since there is only one match statement in this case, wouldn't match-any be equivelent to match-all?
on the other had, if the class map looked like this I understand how match-any would be differant than match-all
     match dscp af41
     match dscp cs4
i.e.
In this case I would expect no packets to ever match since a packet could never have dscp af41 AND dscp cs4
But with the original class-map
     match dscp af41 cs4
Can I assume an OR is applied between "af41 cs4" since it is a single match statement?
Brian Holmes
The match-any or match-all will change from OR to AND for multiple lines.
Match all its acts as a "AND" operation. Where match any does a "OR" operation . if there is only one it does not matter at all, however if there are more than one then you match all of them.
let says you have
     match dscp af41
     match dscp cs4
So when packets arrives, it will matches AF41 and CS4.
     match dscp af41
     match dscp cs4
"Match-any" is OR logic between each line in the class-map.  If any of those entries hold true, so if it has af41 or cs4 the class map will have match
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
648
