Class of Control question -CUCM
A calling Search Space (CSS) is a top-down ordered list of route partitions. Can someone explain what is the benefit of making partition on top. Thanks
Super Bronze
The first thing to understand is that routing on CUCM is done by best match - so if you dial 1234, and there are two route patterns available (e.g. 12xx and 123x) then it will match the 123x route pattern.
The partition order in a CSS is there as a tie breaker. So:
- It is not possible to add two identical patterns/DNs to the same partition. The two examples above (12xx and 123x) are different, so could go in a single partition. However - you could not add 123x twice to the same partition.
- If the same pattern/DN exists in two partitions, then the order within the CSS breaks the tie. the highest order partition is where the call is routed.
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Is there any relationship between Phone line CCS and Route Pattern's route partition ?
Super Bronze
You can dial things that are in a partition that is part of the calling device's CSS.
The calling device's CSS has two parts - the device CSS, and the line CSS. The two are added together, so you get the cumulative total of the two.
Aaron
Hi Aaron Good information
Thank you very much
hi,
does it means that when i dial 1234 and if i want match the 12xx route patten(not 123x), i should config two different partitions and make the 12xx partition in the first order of the css list, is that right?
thanks in advance.
yu.
Super Bronze
Yes, that's exactly it.
Aaron
926
