Class of Restriction - SIP
Hello All,
Can someone point me in the right direction with my config.  I've read the tech notes and have implemented the folloiwng basic COR config on my CME environment but I'ts not restriciting the calls.
In summary I have a SIP handset which I want to only allow internal calls only.  I have the following;
dial-peer cor custom
name internal
name pstn
dial-peer cor list call-internal
member internal
dial-peer cor list call-pstn
member pstn
voice register pool  11
busy-trigger-per-button 2
id mac 1C17.D3C2.5XXX
type 9951
number 1 dn 13
template 2
cor incoming call-internal 1 1  (not sure how the COR tag works as can't find SIP Specifics)
presence call-list
dtmf-relay rtp-nte
username Davidpassword David
codec g711ulaw
camera
video
dial-peer voice 3 pots
trunkgroup PSTN
corlist outgoing call-pstn
description ** Unrestricted **
preference 2
destination-pattern .T
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
no digit-strip
I've been using this as my reference but applies to SCCP.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
Any advice is appreciated
Dave
Everyone's tags (3)
Hall of Fame Super Gold
Update IOS and check again.
VIP Super Bronze
This needs to say:
cor incoming call-internal default
As you have it now, it only applies the cor list against dial-peer tag 1, assuming that's even a legitimate outgoing dial-peer.
Please remember to rate helpful responses and identify helpful or correct answers.
386
