Cleaning up Subscriber Mailboxes in Unity 4.0.5
Hi all,
I am currently on Unity 4.0.5 with Exchange2k. I am in the process of migrating to Unity Connection 8.x. I just ran my first COBRAS Export on Unity and it shows I have about 11GB of voice messages. I would like to find out if there is a way to go into the Deleted folder and remove all messages from there. Also if there is a way to run report that shows how messages in each subscriber's inbox. Basically I am trying to clean up all old messages before running the final COBRAS Export.
Thanks in advance for any inputs / suggestions !!!
D.
1 ACCEPTED SOLUTION
Re: Cleaning up Subscriber Mailboxes in Unity 4.0.5
You may want to take a look at the Message Store Manager utility. See the
following URL to see if it will help you out.
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_tech_note0918
6a00800d6824.shtml
HTH.
Bill
Please remember to rate helpful posts.
On 7/20/10 7:44 PM, "dtran@behr.com"
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
6a00800d6824.shtml
HTH.
Bill
Thanks William !!! Appreciate your help !!!
D.
265
