I'm using CUCM ver. 6.1.1 and TSP ver. 6.1 but I'm not able to get click to dial working with Windows XP. Vista works but not XP which is a little surprising to me. Should I try an older TSP version?
Windows XP is not a tested/supported platform for the TSP 6.1. Click to Dial is supported via Cisco Personal Assistant Server. Right now XP is not supported.
IntroductionCUCM Routing RulesDial String implementation PolicyCUCM Routing LogicSIP URI Call Routing Analysis+++ Case Study: 1 ++++++ Case Study: 2 +++Conclusion
Introduction
Over the last few months, I have had the privilege of working on SI...
view more
Hi All,
Are you getting this error “Installer User Interface Mode Not Supported. The installer cannot run in this UI mode. To specify the interface mode, use the -i command-line option, followed by the UI mode identifier. The value UI mode identifiers...
view more
