CLID and name
I am having trouble configuring my system to allow CLID and name to show up on calls outbound to METRO numbes in our area. I did a debug isdn q931 but it shows my callgoing out as my 4-digit extension (3319) and not the full 10-digit number that I see when I do a trace in the dialed number analyzer. Any suggestions are welcome. See attachment
Hall of Fame Super Gold
Re: CLID and name
You need to mention if you're using CME or CM, and if the latter, H.323 or MGCP.
Re: CLID and name
Sorry about that - we are using CUCM6.1.2.1112-2 with H.323 gateways.
Re: CLID and name
Hi Paul,
I did find soemthing that may impact my issue. I found that on our primary gateway in CUCM we didn't have the "Display IE Delivery" checkbox under Call Routing Information - Outbound Calls. I have reset it but will have to wait till afterhours to reset the VG.
Re: CLID and name
Sorry I meant Paolo, not Paul.
Re: CLID and name
No problem. To send out 10 digits:
voice translation-profile make10
translate calling 10
voice translation-rule 10
rule 1 // /888555/ plan any idsn type any national
voice port 0/y/z:23
translation-profile make10 outgoing
Note this may not work for forwarded depending if you telco accepts any CLID or not.
Re: CLID and name
Wouldn't this dialpeer do what I want as it fowrds 10 digits? I'll check with our carrier to see if they are allowing it or translating to something else too.
dial-peer voice 5 pots
description ** Local 10 Digit **
destination-pattern 9830.......
port 0/0/0:23
forward-digits 10
Re: CLID and name
It forwards 10 digits for called number. Your concern is for calling number.
However, for local calls you should use:
destination-pattern 9[2-9][0-9][0-9]....
You might be billed for long distance when dialing local numbers with an area code.
143
