CLID from H323 gateway with CM 6.0.1
I am using a router with a PRI in it setup as a H323 gateway for PSTN access. It works fine but when a user answers an incoming call the phones don't display the calling number.
I can see that BT are sending the CLID (debug ISDN Q931) but the 7900 phones don't get it.
Is there a setting in CM 6.0.1 or in the IOS config that needs to be changed to enable CLID on incoming calls ?
Pat
1 REPLY
Re: CLID from H323 gateway with CM 6.0.1
Just to follow up on this. The PSTN provioder (BT) had disabled caller id ! When I initially tested it Caller ID was working but at some stage they have disabled it and it no longer shows up in the Q931 debug. So it's not a Cisco issue.
114
