CLID - on incoming calls
I have a CCME with E1 card (PRI).
All incoming calls are showing as "external Unknown Number" is there any way to enable this? or it to do with the teleco NOT sending the numbers????
your help is much appreciated
thanks
  • IP Telephony
Re: CLID - on incoming calls
What is IOS version running on the Router. Could be the Bug ID: CSCsh45544.
Basant
Hi Basant,
see below
show ver
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 12.4(11)XW5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Sat 17-Nov-07 10:08 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
SX-BROOME-CCME uptime is 37 minutes
System returned to ROM by bus error at PC 0x42E92170, address 0x20494B45 at 07:59:01 WST Thu Jun 5 2008
System restarted at 08:00:53 WST Thu Jun 5 2008
System image file is "flash:c2800nm-adventerprisek9-mz.124-11.XW5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2821 (revision 53.50) with 245760K/16384K bytes of memory.
Processor board ID FHK1205F0DL
2 Gigabit Ethernet interfaces
12 Serial interfaces
1 ATM interface
1 terminal line
2 Channelized E1/PRI ports
1 Virtual Private Network (VPN) Module
4 Voice FXS interfaces
1 cisco service engine(s)
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
103
