clock calendar-valid invalid command error
Hi techs,
Hopefully this is a simple issue
Want to resolve error of when updating cisco phone configuration files via create cnf-files I get error of
%Error deleting flash:SEPDEFAULT.cnf (No such file or directory)
%Error deleting flash:XMLDefault.cnf.xml (No such file or directory)
Is a file in flash: called xmldefault7912.cnf but none as named above
Upon searching via google for introduction of clock calendar-valid command..cisco site shows IOS 10.0 onwards for which I have 12.2 via cme 3.3
Upon searching for reasoning of %Error deleting flash:SEPDEFAULT.cnf (No such file or directory), a Cisco site http://www.oocities.org/manojkreddyutl/cisco/150.htm
leads me to run the clock calendar-valid command but I get error of invalid command error under conf t
I have ntp master set though
Please advise further
Thanks in advance again.. :) :)
Green
Hi JohnCan you make sure you
Hi John
Can you make sure you have the following commands in your config
tftp-server flash:SEPDEFAULT.cnf
tftp-server flash:XMLDefault.cnf.xml
Also the command "clock calendar-valid" is hardware dependant
If your router is old then it most likely wil not
take this command
Alex
Regards, Alex. Please rate useful posts.
Hi Alex,Thanks for your reply
Hi Alex,
Thanks for your reply. Tried your resolution to no affect
Below is the message response
cme_router#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
cme_router(config)#telephony-service
cme_router(config-telephony)#create cnf-files
CNF file creation is already On
Updating CNF files
CNF files update complete
57
