Cluster CM6.1 - Testing Redundancy and Fallback
Hi!
How can I be sure that the redundancy offered by the cluster solution is really working? I mean, how can I be sure that if the publisher crashes, the subscriber will guarantee the CM services?
Ana
Re: Cluster CM6.1 - Testing Redundancy and Fallback
first of all check your CCM groups config and confirm the phone has both in their config, then:
a) stop CCM service
b) use an ACL to block communication phone-ccm
java
if this helps, please rate
java
www.cisco.com/go/pdi
Hi!
On System > Cisco Unified CM Group I can see the Publisher and the subscriber. Is this enough to check CCM groups config?
On one of the phone's browser page I have on the network configuration:
CallManager 1 (CM Pub. IP)active
CallManager 2 (CM Subsc. IP)suspended
CallManager 3 (gateway IP)
Does this seem OK?
yes, that seems fine on config, now you need to test it
java
java
140
