Cluster Limit questions
Is there a limit to how many non-CM service based servers can be in a cluster such as MOH or TFTP?
Manish
Re: Cluster Limit questions
With Cisco Unified CM 7.x, a cluster may contain as many as 20 servers, of which a maximum of eight may run the Cisco CallManager Service that provides call processing. The other servers may be configured as a dedicated database publisher, dedicated Trivial File Transfer Protocol (TFTP) server, or music on hold (MoH) servers. Media streaming applications (conference bridge or media termination point) may also be enabled on a separate server that registers with the cluster.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/callpros.html
If not your version, review the same chapter from the SRND for your CUCM version.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Yes, but it depends on CUCM version.  Hard and fast rules.  1 Publisher.  8 Subscribers.  From there, you can have
additional "cluster" servers that serve specific purposes without providing specific DB or call-processing functions such as
TFTP, MoH, etc.
Java's link to the SRND should be sufficient to give you the numbers you need for your version.  Any further questions, just ask.
197
