Cluster Security with One etoken?
Hi guys,
is it possible to setup the initial Cluster Security Mode with only one etoken?
It is for my homelab, and if the etoken is lost ore damaged, that doesn't matter!
I like to keep my lab cheap!
Regards Paul
1 ACCEPTED SOLUTION
Blue
hi Paul,
yes you can do it without second token, Second token is only usd when frist one is lost.
So In LAb it should be ok.
Ronak patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Blue
hi Paul,
Ronak patel
Rate helpful posts.
Sorry Ronak,
i can't do a secure cluster with one token. The CTL Client wants a second token....
Hi Paul,
You need two tokens to set up the initial CTL file, and you only need 1 token if you need to update the CTL file.
HTH,
Chris
203
