Clusters and gateways
Is it possible to make a voice gateway accessible by two different clusters?
-Shikamaru
Green
Re: Clusters and gateways
Yes, if using H323 or SIP.
Or 1 using MGCP and the other H323|SIP
Okay, so I take it that it is not possible with MGCP.
-Shikamaru
No, you can't share a gateway using MGCP. The easy (and proper) way is to just setup an intercluster trunk. Let one cluster run the gateway and the other cluster sends calls to the gateway over the trunk.
103
