12-04-2007 07:23 PM - edited 03-15-2019 07:35 AM
Is there a way to log logins and activity when admins login to administer callmanager after Multilevel Administration has been enabled?
12-05-2007 03:17 AM
I think so, it should be there on C:\Program Files\Cisco\MLA..
12-05-2007 05:43 AM
There is a folder c:\program files\cisco\trave\ma that has text files with a little information. Anyway to import this into a utility (Trace Collection Tool) etc. to make it more pleasing to the eye?
12-05-2007 09:36 AM
I import the trace files for MLA into an excel document, as a delimited file. I use the | symbol to seperate the columns. This allows me to sort/filter based on any number of criteria.
12-05-2007 10:23 AM
OK thanks I will give it a try.
