Community Member
CM 4.1.3 Multilevel Administration
Is there a way to log logins and activity when admins login to administer callmanager after Multilevel Administration has been enabled?
Community Member
Re: CM 4.1.3 Multilevel Administration
I think so, it should be there on C:\Program Files\Cisco\MLA..
Community Member
There is a folder c:\program files\cisco\trave\ma that has text files with a little information. Anyway to import this into a utility (Trace Collection Tool) etc. to make it more pleasing to the eye?
Community Member
I import the trace files for MLA into an excel document, as a delimited file. I use the | symbol to seperate the columns. This allows me to sort/filter based on any number of criteria.
Community Member
OK thanks I will give it a try.
122
