Cm 4.1 h.323 trunk with CME send name
Hi everybody!
I have CM 4.1 and  h.323 trunk to CCME.
I need send calling party name to CCME.
For example "Mikhail Chernyakov"
but CCME only recived number....
Can I configure CM 4.1 to send calling name to trunk? Can I enable it at UTF 8 Format?
Thank you veru much!
1 REPLY
on CUCM the H323 Gateway which is configured to connect to your CCME, check the box next to "Display IE Deliver" and reset the gateway (This is cause active calls to drop, therefore do it off business hours).
95
