CM 4.2(1) Blocking Internal CLI
I need to block the CLI for a single line internally. External isn't a problem, but how can I prevent other internal IP phones from seeing the number?
Ideally the called phone should show the name/dept of the caller, but not their number.
Re: CM 4.2(1) Blocking Internal CLI
HI,
I want the same....Did you found a solution?
Reg
Goen
Call Display Restrictions
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_2_1/ccmfeat/fshosp.html
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
102
