CM 4.2 DLLHOST.EXE service is increasing the memory usage
i have CM 4.2 and on the Publisher the DLLHOST.EXE service started to increase the memory usage.
Re: CM 4.2 DLLHOST.EXE service is increasing the memory usage
Like all windows servers, they should be rebooted from time to time. Memory leaks to occur and not uncommon. I would reboot and monitor it. If the memory spikes up quickly, there is an issue. If it takes a month for it to leak, that's probably normal.
I already rebooted it and still have the same issue on the Publisher only, is that related to any bug.
142
