Hi Reckhardt,
I assume that you are using DCD and running CCMPWDChanger in the PUB.
the password must be the same in all servers (Actullay ccmpwdchanger should have done that)
anyways, please try the following:
According to your description, your system is working fine, except for the access to the DC Directory Admin; then there is a script that should change the password.
Please try this:
Resolution: Force manual password change in DC Directory
1. Create a file named "fixadmin.txi" containing the following text between
the + signs (do not copy the + signs):
ModifyDSE /o=cisco.com/cn="Directory Manager"
RemoveAttribute UserPassword
AddAttribute UserPassword ciscocisco
2. Copy the file fixadmin.txi to C:\DCDSrvr\run\dcx500\config and then run
3. Open a command prompt window, type the following: cdsadmin fixadmin
4. Then restart DC Directory Server
5. Try to log in to the dcd admin tool (start > programs > DC Directory
Administration). The user name will be Directory Manager, and the password
will be ciscocisco.
